AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Replace F1 Help with Macro
1 REPLY 1
jsebclark_SDG
657 Views, 1 Reply
I have search everywhere to figure out how to replace the F1 key with a macro. I have read everything and tried everything. This is my last hope.
The Problem:
I have reassigned the F1 to Intersection Snap. What happens is that every time that I press F1 it opens help. When I return to ACA I can see in the command line the following:
'_.help
_int
So to me it looks like it is executing help and then picking up the reassigned value for F1. And in fact after I return to ACA I can snap to the intersection of whatever I need.
How to I get it to stop executing help?
1 REPLY 1
I figured out the problem.
I had ACA 2010 installed without the express tools. When I reinstalled it with the express tools, the F1 reassignment worked as expected. So I guess one needs to have the express tool installed to get some of the CUI customizations to work.
”Boost
