• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Publishing multi sheet to a single pdf file
    835 Views, 5 Replies
    08-05-2011 07:32 AM
    I changed my Publish options on the Project Navigator  for publishing to PDF as a single sheet per sheet layout.  Now I want to put it back so that when I publish it does ALL sheet into one PDF file and I can not figure out how to put it back. Now ever time I publish it does each sheet as a separate pdf.
    Can some one help me before I jump out the window!!
    Not to worry I’m on the first floor but this is really frustrating
    Todd
    Please use plain text.
    Valued Contributor
    Re: Publishing multi sheet to a single pdf file
    08-05-2011 07:44 AM in reply to: ktttallen
    In the publish dialog click "Publish Options" under the "General DWF/PDF options" the first line is Type that is a drop down. Change it from Single Sheet file to Multi-Sheet File.
    Active Contributor
    08-05-2011 08:12 AM in reply to: GRandall
    I have tried changing it and it does Nothing, still comes out as seperate pdf files. There is many ways to get to the publish diolog box. typicaly i right click in my project Navg. But i have tried it vie several other options
    *Expert Elite*
    08-08-2011 01:15 PM in reply to: ktttallen
    PUBLISHCOLLATE = 1
    New Member
    tim1984
    04-20-2012 01:02 AM in reply to: ToanDN
    Hi everyone,
    I'm in trouble with publish. I live the same problem with  first mesaage in this topic. And i try to solution offers.
    But they didn't worked in my case.
    Can i do something differnt?
    Can help me anyone?
    New Member
    01-16-2013 12:45 PM in reply to: tim1984
    IS NEEDED TO HAVE A PAGE SETUP APPLIED TO EVERY LAYOUT. IN THIS WAY IT WORKS WITH THE MULTISHEET FUNCTION.
    IN DIFFERENT WORDS, U CANT HAVE "NONE" AS PAGE SETUP APPLIED IN THE PUBLISH DIALOG.
