• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Valued Contributor
    Properties for AEC objects not displaying in Properties Palette
    270 Views, 13 Replies
    01-16-2012 09:17 AM
    A user showed me today that she cannot see any properties for a wall, door, or other AEC object in the Properties palette.
    Some options like height, width, etc. are shown, but not layer, style, etc. from the General portion of the Basic tab.
    Is this going to be a reinstall scenario or is there a fix for this?
    Matt
    Product Support
    Re: Properties for AEC objects not displaying in Properties Palette
    01-19-2012 01:48 AM in reply to: CCAP
    Can you post us a screen capture?  www.jingproject.com is a free download that does a great capture.
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    01-20-2012 12:29 PM in reply to: Joshua.Benoist
    Apologies for not getting back sooner.  I've been swamped on some deadlines and as the problem is on another user's computer, I haven't had a chance to get a screenshot yet.  I have left myself a note to do so and will post back as soon as I have it.  Thanks!
    Product Support
    01-25-2012 11:23 AM in reply to: CCAP
    Bump.  ;-)
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    Valued Contributor
    02-06-2012 05:10 AM in reply to: Joshua.Benoist
    FINALLY!  Sorry this took so long.  Below is what we see when we click a wall to see its properties.  As you can see, the properties palette shows nothing for Layer, Style, etc.  Obviously I can just reinstall.  But, I thought if this were something someone knew a fix for, I could save some time.
    Thanks!
    P.S.: This image also shows another issue two of our computers are having.  We have shared palettes stored on our server and these two computers initially show no thumbnails for the tools.  Refreshing the palette brings them back.  More of an annoyance than anything.  But, still troublesome.
    New Member
    03-06-2012 09:43 AM in reply to: CCAP
    bump! - i'm having exactly this problem - please take a close look.  i've done the reinstall and still has the same issue.  thanks.
    Product Support
    03-07-2012 08:49 AM in reply to: jpn2012
    The palettes seen in the image look like core AutoCAD palettes and not AutoCAD Architecture palettes.  The core AutoCAD palettes and objects inserted off of them, do not have Architectural properties like layer key etc.  You need to use the Architectural palettes.  Are you running Architecture as Core AutoCAD?
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    Product Support
    03-07-2012 08:56 AM in reply to: Joshua.Benoist
    These are the Architectural palettes.
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    Valued Contributor
    03-07-2012 09:03 AM in reply to: Joshua.Benoist
    The palettes shown are our custom built 2D palettes.  What is placed in the drawing by using these tools is NOT the issue.  As you can see in the screen shot, there is a stock AEC wall selected and it is showing no properties as it would on any other machine in our office.
    The tool palettes not showing thumbnails is an entirely separate issue.
    New Member
    03-07-2012 09:54 AM in reply to: CCAP
    CCAP has it correct - that is the same problem that I'm having.  It has nothing to do with the Architectural palettes, is the PROPERTIES palette not displaying wall/window (any AEC object) properties.  Many of these properties (Style, Layer, Sizes, etc) are the primary editing interface to select and set the correct AEC object properties.
