• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Problems with 'dwg to pdf.pc3'
    161 Views, 4 Replies
    02-07-2012 06:27 AM
    Is anyone else having problems with the otb 'dwg to pdf.pc3', or is it just me?
    Every time I try to modify something about it (custom paper sizes, font handling, output settings) it results in fatal errors. Really starting to be annoying....
    Pierre P.
    Pierre P.
    ACA 2012
    Windows 7
    Intel Core i7-2600 CPU
    3.4GHz - 8GB ram - 64 bit
    ****Sage
    Re: Problems with 'dwg to pdf.pc3'
    02-07-2012 06:34 AM in reply to: CarrierSavard
    You never mention your ACA version here or in your other post with the same issue.
    Works fine here, so try only changing one thing at a time and see when does it fail. Then start by changing two things, then three and so on.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Product Support
    02-22-2012 08:49 PM in reply to: CarrierSavard
    I just wanted to check back in and see if there was anything further we could help with on this inquiry.  Please let us know if further assistance is needed in the community and if not please let us know so we and/or you can mark this post as solved.  Thank you and we look forward to your update.
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    02-23-2012 05:52 AM in reply to: MichaelBussiere2
    Thanks for checking up
    It's been working on and off for a while, but I've put that issue aside for now in order to fix other things.
    I'll take a little more time to try and figure out what's causing the problems.
    As soon I figure it out, I'll  let you know.
    Cheers
    Pierre P.
    Pierre P.
    ACA 2012
    Windows 7
    Product Support
    02-29-2012 06:03 PM in reply to: CarrierSavard
    Thank you for your reply.  Please keep us posted in the community and if it should occur again please post back and let us all know so members can help contribute towards possible resolutions.  Thank you.
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
