AutoCAD Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problems with 'dwg to pdf.pc3'
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is anyone else having problems with the otb 'dwg to pdf.pc3', or is it just me?
Every time I try to modify something about it (custom paper sizes, font handling, output settings) it results in fatal errors. Really starting to be annoying....
Pierre P.
ACA 2012
Windows 7
Intel Core i7-2600 CPU
3.4GHz - 8GB ram - 64 bit
Re: Problems with 'dwg to pdf.pc3'
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You never mention your ACA version here or in your other post with the same issue.
Works fine here, so try only changing one thing at a time and see when does it fail. Then start by changing two things, then three and so on.
Dean Saadallah
http://LTisACAD.blogspot.com
RSS: http://ltisacad.blogspot.com/feeds/posts/default
Twitter: http://twitter.com/LTisACAD
Pinterest: http://pinterest.com/pendeaninc/pins/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just wanted to check back in and see if there was anything further we could help with on this inquiry. Please let us know if further assistance is needed in the community and if not please let us know so we and/or you can mark this post as solved. Thank you and we look forward to your update.
Michael Bussiere II
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for checking up
It's been working on and off for a while, but I've put that issue aside for now in order to fix other things.
I'll take a little more time to try and figure out what's causing the problems.
As soon I figure it out, I'll let you know.
Cheers
Pierre P.
ACA 2012
Windows 7
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your reply. Please keep us posted in the community and if it should occur again please post back and let us all know so members can help contribute towards possible resolutions. Thank you.
Michael Bussiere II
Support Specialist
Product Support
