• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Plotting and Printing gets cancelled.
    105 Views, 5 Replies
    10-08-2012 03:37 PM
    Suddenly, each time that I attempt to plot or print a drawing I get the message "Errors or Warnings Found".  I open it up and it shows that the plot has been cancelled.  I have run all of the "traps" that I know but to no avail.  Anyone have a suggestion?
    Ray Cox
    Please use plain text.
    Valued Mentor
    leothebuilder
    Re: Plotting and Printing gets cancelled.
    10-09-2012 07:30 AM in reply to: RAYCOX5805
    Need more info.....what kind of plotter do you have installed.
    Does the error warning say anything else that could identify the problem.
    Is printer connected to computer or network.
    Have you tried publishing to PDF/DWF and than print the PDF/DWF to the printer/plotter
    Active Contributor
    10-09-2012 11:54 AM in reply to: leothebuilder
    My plotter is a HP Designjet 500 but even when I attempt to plot a drawing as a pdf I get the same message. Ray Cox
    Valued Mentor
    leothebuilder
    10-09-2012 11:57 AM in reply to: RAYCOX5805
    Do you use a named page setup, or do you reset each time you plot.
    Is it a large drawing file?
    maybe you can post the file.
    Active Contributor
    10-09-2012 01:04 PM in reply to: RAYCOX5805
    I did a repair run and that partially resolved the problem although I sometimes have to make two or three attempts before it finally plots.  Thanks for your help.  I will continue to attempt to solve the problm.
    Ray
    New Member
    BarbraDavis7455
    10-25-2012 01:19 PM in reply to: RAYCOX5805
    Ray, I seem to be having the indentical problem you experienced.  Have you found a solution that has corrected the problem?  You mentioned that you ran a repair run, can you explain how you did that?
    Thank you
    Barb
