AutoCAD Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Plotting and Printing gets cancelled.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Suddenly, each time that I attempt to plot or print a drawing I get the message "Errors or Warnings Found". I open it up and it shows that the plot has been cancelled. I have run all of the "traps" that I know but to no avail. Anyone have a suggestion?
Ray Cox
Re: Plotting and Printing gets cancelled.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Need more info.....what kind of plotter do you have installed.
Does the error warning say anything else that could identify the problem.
Is printer connected to computer or network.
Have you tried publishing to PDF/DWF and than print the PDF/DWF to the printer/plotter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you use a named page setup, or do you reset each time you plot.
Is it a large drawing file?
maybe you can post the file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did a repair run and that partially resolved the problem although I sometimes have to make two or three attempts before it finally plots. Thanks for your help. I will continue to attempt to solve the problm.
Ray
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ray, I seem to be having the indentical problem you experienced. Have you found a solution that has corrected the problem? You mentioned that you ran a repair run, can you explain how you did that?
Thank you
Barb
