• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    doug.mayer
    Accepted Solution
    Pinning "Recent Documents" in main menu
    111 Views, 3 Replies
    04-02-2012 10:24 AM
    Working in ACA 2012 on a Windows 7 machine.  Noticed that pinning documents in the "Recent Documents" under the main menu is acting goofy.  If I pin a document (so that it presumably stays there no matter what) and then open other drawings, the pinned drawing gets pushed down the list just like any other.  Eventually, it gets pushed off the list just like all the others.
    Is there a system variable I'm not aware of that controls this feature?  Or is this just a bug, but since this feature is rarely used no one has noticed it?
    Doug Mayer, SE
    CAD Systems Manager
    Please use plain text.
    Product Support
    Re: Pinning "Recent Documents" in main menu
    04-11-2012 09:43 AM in reply to: doug.mayer
    Within ACA2012 you should be able to pin the drawing file using the pin icon to the recent documents list from the applications menu.  Once it is pinned it will move down the list (by default and as designed) but it will stay listed.  I have made a quick video illustrating this below.  If your software is not responding as shown, please test a different Windows User login to see if that user then gets the same results.
    Video: http://screencast.com/t/LZWuRd32P2O2
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    doug.mayer
    04-11-2012 10:31 AM in reply to: MichaelBussiere2
    The pinned recent document is behaving as you described it should.  I had a user that swore that the pinned recent document was being pushed off the list, but after standing over his shoulder and trying it again, it worked as it should.  Thanks for the help.
    Doug Mayer, SE
    CAD Systems Manager
    Product Support
    05-10-2012 06:45 AM in reply to: doug.mayer
    You are welcome and I am glad it helped.
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
