• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Valued Contributor
    BBP-Arch
    .PDF's take forever to plot
    138 Views, 4 Replies
    01-24-2012 01:23 PM
    ACA2011
    Every time I try to plot something with a PDF embedded it takes a very long time to spool and plot. Additionally, a PDF in the drawing slows it down so significantly it's almost not worth using...  This happens whether the PDF is less than 1 MB or 50 MB...no difference. Has this been fixed in 2012? Why to PDF's do such a drain on system rescources when they're such small files to begin with?
    Scott
    ****Sage
    Re: .PDF's take forever to plot
    01-24-2012 01:34 PM in reply to: BBP-Arch
    There is no compression, so plot files are huge in comparison (but all the end user sees is "longer spool/plot times"). As a test, plot to FILE with and without a PDF in the same file and compare. Faster connections and devices with harddrives help there.
    What PC specs and OS are you using? There is no specific improvement in ACA2012 for on screen performance but it can be less of an issue if your PC is not at the bare minimum end of the system requirements scale.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Valued Contributor
    BBP-Arch
    01-25-2012 01:34 PM in reply to: pendean
    Thanks for the response...my machine is old: xi Computer: 2.8 GHz, 3 GB RAM, NVIDIA Quadro FX 550 Video Card.
    Product Support
    01-27-2012 01:41 PM in reply to: BBP-Arch
    In this case and per these system specifications you may notice some problems with overall functionality/performance.  In the current configuration you can increase the virtual memory by activating the 3Gig switch per the link below but with only 3 gigs installed you may not see night and day improvements.  What we have seen is the best performance gains from this switch are gained with 4 gigs installed on the 32x O.S.
    3Gb Switch: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9583842&linkID=9240617
    Additionally the graphics card you have listed with the 2011 product line in your environment may need one of the latest certified drivers listed in the screen shot link below.  To download one of these drivers please use the second link to navigate to the certified hardware list.
    Graphics Card 550 FX listed:  http://screencast.com/t/4xuC2KL7PxW5
    Certified Hardware:  http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
    Michael Bussiere II
    Support Specialist
    Product Support
    Valued Contributor
    BBP-Arch
    01-27-2012 04:43 PM in reply to: MichaelBussiere2
    Thanks for the info! I'll see what I can do with that.
