• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    No ribbon on AutoCAD
    951 Views, 10 Replies
    05-17-2011 03:47 AM
    I've installed AutoCAD, a few times now, and everytime the ribbon does not appear and I get the error "unknown command" if I type ribbon in the CLI.
    please help
    tony
    Please use plain text.
    Member
    anmussara22
    Re: No ribbon on AutoCAD
    05-25-2011 07:47 AM in reply to: tebo-citrix
    Here's your fix:
    Type in the command prompt: menubar
    Type "1" for your selection
    All the regular pull down menus should appear at the top (File, Edit, View, etc....)
    Click on "Tools" and move your mouse to "Workspaces", Select the type of AutoCAD style you are working in (2D Drafting & Annotation, 3D Basics, etc...)
    Your ribbons should appear.
    Good luck!
    10-12-2011 05:45 AM in reply to: tebo-citrix
    No luck
    When you type menubar and 1 all I get is file|window|help ?
    any other idea's
    Product Support
    10-13-2011 09:56 PM in reply to: tebo-citrix
    Try this:
    1. Make sure you have ACA.cui loaded by:
    • Type CUI -> go the customize tab. Check if ACA.cui is loaded.
    • Right click ACA and select restore CUI.
    • Apply and close.
    1. Load the correct CUI.
    • Type Menuload on the command prompt.
    • Unload any existing CUI that is loaded.
    • Click browse and locate the ACA.cui from the support folder.
    • Click Load.
    This should bring the ribbon back on the screen
    Niranjan Kamath
    Autodesk, Inc.
    Product Support
    10-13-2011 09:58 PM in reply to: niranjan.kamath
    In case if you are using Autocad profile then use the same to load the ACAD.cui
     ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Niranjan Kamath
    Autodesk, Inc.
    10-17-2011 04:44 AM in reply to: niranjan.kamath
    Still no luck, I've installed AutoCAD 2012 on the same machine, and get the same issue.
    have you got any other idea's ?
    thanks for your help tony
    Active Contributor
    10-17-2011 11:07 PM in reply to: tebo-citrix
    I'm guessing that on install of 2012 you've migrated the current autocad-profile?
    Could you try and startup a not yet existing autocad-profile. Because probably your profile became corrupted (i.e. search paths) causing autocad not to find the needed files....
    Copy the autocad shortcut calling it 'autocad test' or something.
    Change the shortcut target to "C:\Program Files\Autodesk\AutoCAD Architecture 2012\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD Architecture 2012\AecBase.dbx" /p "AutoCAD Architecture (TEST)"
    You will get (if that is even possible) a 'vanilla' version of AutoCAD Architecture.
    Maybe you could try and add to that profile to create a new working profile.
    Grtz,
    Tijgervisuals.
    10-24-2011 04:35 AM in reply to: bronstijn
    No luck again, still no ribbon,
    do you think this is a bug ?
    Product Support
    10-27-2011 09:00 PM in reply to: tebo-citrix
    Did by any chance migrated your old setting to 2012? Check if resetting the application helps
    Windows -> All Programs -> Autodesk -> AutoCAD 2012 -> Reset Settings to Default
    And check if this helps in our case?
    Niranjan Kamath
    Autodesk, Inc.
    11-03-2011 07:22 AM in reply to: niranjan.kamath
    What does the Ribbon need to be installed for it to work, I'm running this on a windows 2008 system, would that make a difference ?
