AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Need a lisp to set SHADEMODE to wireframe currnt lisp dosnt work?
4 REPLIES 4
716 Views, 4 Replies
We need a lisp to set our SHADEMODE to wire frame. However is the following isn't working for me.
(command "SHADEMODE" "wireframe")
4 REPLIES 4
(command "SHADEMODE" "2") would be better. Justo.
just returns nil, tryed it before
The command function in lisp always returns nil. Try a shade view and then invoque the code sent before to see the effect.
Justo.
David_W_Koch
Depending upon what version you are using, you may want to use the VSCURRENT command, rather than SHADEMODE.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
