• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture Customization
    The_Caddie
    Accepted Solution
    Need a lisp to set SHADEMODE to wireframe currnt lisp dosnt work?
    138 Views, 4 Replies
    03-05-2012 01:01 AM
    We need a lisp to set our SHADEMODE to wire frame. However is the following isn't working for me.
    (command "SHADEMODE" "wireframe")
    Please use plain text.
    Valued Contributor
    Re: Need a lisp to set SHADEMODE to wireframe currnt lisp dosnt work?
    03-05-2012 05:39 AM in reply to: The_Caddie
    (command "SHADEMODE" "2") would be better. Justo.
    The_Caddie
    03-05-2012 06:51 AM in reply to: JustoAg
    just returns nil, tryed it before
    Valued Contributor
    03-05-2012 07:03 AM in reply to: The_Caddie
    The command function in lisp always returns nil. Try a shade view and then invoque the code sent before to see the effect.
    Justo.
    *Expert Elite*
    03-05-2012 04:38 PM in reply to: The_Caddie
    Depending upon what version you are using, you may want to use the VSCURRENT command, rather than SHADEMODE.
    David Koch
