I am in need of some advice on the following customization questions:
1. I would like to implement Paul Aubin's suggestion to implement STB
plotting using lineweights in the drawing with a custom STB file that uses
just "BLACK", "COLOR," and "SCREENED" styles with lineweights handling pen
size. All of the styles in ADT 2004 have an AIA.stb assigned that uses
multiple styles to control plotting (THIN; FINE, BOLD, etc....) Any
suggestions on how to change all these styles? What I have found so far is
that my custom STB file reports that "THIN" is missing, etc....
2. I have read in this NG that if we try and load the ACAD.MNS we will
cause terrible problems. I would like to customize the ADT menus to add
some of the old AutoCAD commands and need to know how best to do this. An
authoritative comment would be appreciated.
3. In ADT 3.3 I had created custom Display Reps for Floor Plan 96 (1/8"
Scale) and Floor Plan 48 (1/4" Scale) which actually changed lineweights
based on the scale. This way plans at 1/8" scale had an appropriately
thinner lineweight then those at 1/4" scale. I had postponed further
Display Rep customization until ADT 2004 was released. My question is this:
Now with Low, Medium and High Detail Displays how best can I implement this
same strategy? Also, I noticed that there seemed to be a duplication of my
custom reps. (Please see my post " Re: Scale Dependant Display Reps and
Annotation in ADT 2004?" in the ADT 3.3 NG which has a Screen Capture of the
error message I received). I want to avoid this problem in ADT 2004 so need
some good advice. As a side note the reason for this (even in ADT 2004) is
that the level of detail and lineweights used is too much for a 1/8" plan
and plots as a "blob" of black ink. I noticed this even in ADT 2004 wall
styles for Medium Detail (which seems to be set up for 1/8" Plans).
I want to make ADT 2004 as "perfect" as I can since it looks like this may
be the last upgrade for us for a while. The Autodesk Subscription for our
five seats of ADT jumped to $3,400 for the next year and it looks like my
superiors will not approve that expense for the 4-5 more Extensions we would
receive this year on the Subscription. I have been instructed that we may
only look at upgrades every five years or so from now on so I want to
complete my customization as extensively as possible to make us as
productive and profitable as possible.
I have a host of other questions that I will be posting soon.
As always thanks for your help and advice.
Sincerely,
D. Kuhn
