• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    New Member
    jmetz1
    Monochrome.ctb plot style table missing
    7204 Views, 6 Replies
    09-01-2010 11:59 AM
    Has anyone had the problem with the monochrome .ctb plot style table not showing up in the plot dialogue for AutoCAD Architecture 2010? Typically it seems to be standard upon install of the software. Any help is greatly appreciated.
    Please use plain text.
    Re: Monochrome.ctb plot style table missing
    09-01-2010 03:55 PM in reply to: jmetz1
    Are you being offered CTB files as the choice for your plot, and it is just the monochrome.ctb file that is missing?  Is your drawing set up to use color-dependent plot styles?  If not, you will not be offered any CTB files as a choice, only STB files.
    Start new files with a template that uses the desired plot style type; use the CONVERTPSTYLES command to change from STB to CTB, if necessary, in an existing file.
    David Koch
    New Member
    jmetz1
    09-20-2010 05:37 AM in reply to: jmetz1
    Thank you David, that worked just fine!
    New Member
    nazag
    03-10-2011 08:46 AM in reply to: David_W._Koch
    Thank you David, you are my hero !!!
    New Member
    galdamezra
    04-10-2011 09:25 PM in reply to: nazag
    thanks david. definitely solved my problem too!
    New Member
    06-15-2012 09:43 AM in reply to: David_W._Koch
    Great man! Tanks =D
    New Member
    10-03-2012 03:48 AM in reply to: David_W._Koch
    thanks david,
    save me lots of time :robothappy:
