I am having a lag problem when quickly zooming in or using the selection window quickly. When quickly picking a window from left to right the first pick point lags and I would select some thing else. Iam using Cad 2012. Is there a command setting that has changed from Cad 2011 to 2012 ??
Sorry I typed a novel but the forum truncated it to one letter. I will be brief, I have no
time for this.
We have been complaining about this too.
Update your video driver to a certified one. Be aware that other software you use might
not like the new driver. I apparently can't post the link so google "autodesk certified video cards".
3dconfig to verify that your video card and driver are certified.
rollovertips = 0
Try turning off all "status toggles" except snap and
ortho. I don't know what these are
called, but they are at the bottom left of your screen.
This is not going to fix the problem, but it should help get you
by until the service pack is released.
I hope this helps, good luck.
*Autodesk, please release a service pack soon. People are going crazy. Also, the error reports we are trying to
submit are not going through.
