Kewl. Do you have the ZIPS? If not, I can email to you, now that I've
downloaded them 🙂
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
"Rob Starz" wrote in message
news:8E2C38CC0FC53CB4E0AD645C6E57BE20@in.WebX.maYIadrTaRb...
> Matt,
> If you want I can post it to a section of my site so you don't have to
> search the NG latter on.
> Let me know and if there is more NCS content send it to me and I will
post.
> I have 100 gigs of storage on my server to size is not an issue.
> Rob Starz
> Stardsign cad solutions
> www.stardsign.com
> "Matt Dillon" wrote in message
> news:C10DC63FE82A7612B467E2838D484A86@in.WebX.maYIadrTaRb...
> > Thanks for saving me some effort, David 🙂
> > Matt Dillon
> > "David_W._Koch" wrote in message
> > news:f190a0f.4@WebX.maYIadrTaRb...
> > Is now soon enough? I apologize for not having access to Matt's raw
files,
> I
> > had to post copies of the originally posted ZIP files :-). I would
imagine
> > the only difference would be that the ZIP files he originally posted
> contain
> > folder information. I also decided to post them to the Customer Files
> > newsgroup, under the topic "Matt Dillon's NCS Content Files [ADT3.3]",
due
> > to the fairly hefty size of each ZIP file - hope you have broadband
> access.
> > Note also that since I was posting from the web-based interface, I was
> > limited to one attachment per post, so there are two posts in that
thread.
> > The first has the Imperial content ZIP file; the other has the Metric
> > content ZIP file. If you are downloading these from the web-based
> interface,
> > the first post will be accessible when you first select the link to the
> > thread from the left pane, but in order to access the Metric file, you
> will
> > need to select the link to the second post in the top right pane prior
to
> > trying to download that file [from the lower right pane].
> > The Customer Files newsgroup can be accessed via the web-based interface
> > at -->
> > http://discussion.autodesk.com/WebX?14@@.ee940b5
> > <-- [watch for word wrap], or via a newsreader at -->
> > news://discussion.autodesk.com/autodesk.autocad.customer-files
> > <-- [watch for word wrap].
> > ZIP all files prior to posting. If you use the newsreader access, make
the
> > ZIP file an attachment to your post. If you use the web-based interface,
> > there is the usual place to type explanatory text for your post, and an
> edit
> > box at the bottom where you type in the path and name of the ZIP file,
or
> > use the Browse button to navigate to it (usually easier).
> > David Koch
> > Member of the Autodesk Discussion Forum Moderator Program
