• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Inserting a door doesn't cut into the wall anymore
    390 Views, 10 Replies
    08-01-2007 12:08 PM
    Just out of the blue, inserting a door into a wall, any type of wall, the door gets inserted but the wall doesn't cut an opening. The wall still shows up going thru the opening of the wall. 'I've have tried display setting from Low Detail to Presentation with the same results. Anyone with some ideas on what's going on.
    Mike Message was edited by: mmyers
    Please use plain text.
    Active Contributor
    Re: Inserting a door doesn't cut into the wall anymore
    08-01-2007 12:18 PM in reply to: mmyers
    Here is example of what I mean with the attached file.
    *Charlie Peil
    08-01-2007 01:39 PM in reply to: mmyers
    Are the sill lines turned on in the sill display rep?
    Charlie
    Distinguished Contributor
    08-01-2007 02:02 PM in reply to: mmyers
    are both the door and wall at an elevation of 0?
    08-01-2007 04:03 PM in reply to: mmyers
    What Display Configuration is set current, and does the cut plane cut through the doors?
    David Koch
    Autodesk Discussion Group Facilitator
    Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
    Active Member
    08-02-2007 03:45 AM in reply to: mmyers
    Can you attach a sample file with just one wall and door from the same file.if the actual file is not heavy, you can attach it directly.This will make it easy to solve the issue.
    regards,
    T
    Active Contributor
    08-02-2007 05:50 AM in reply to: mmyers
    I believe the sills are turn on. The cut plane is set to 0 and the doors don't cut thru and display setting. Here is the example file that you requested. Please let me know what you find out.
    Thanks Message was edited by: mmyers
    *Dustin
    08-02-2007 07:47 AM in reply to: mmyers
    your door is below the cut plane its only 8" tall.
    wrote in message news:5677553@discussion.autodesk.com...
    Active Contributor
    08-02-2007 08:01 AM in reply to: mmyers
    I really feel about 8" tall right now
    Mike
    *Dustin
    08-02-2007 08:04 AM in reply to: mmyers
    ahh, we've all been there in one way or another.
    wrote in message news:5677795@discussion.autodesk.com...
    Mike
