• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Accepted Solution
    Help - Walls and Doors not visible in viewports!
    66 Views, 2 Replies
    02-08-2012 05:56 AM
    I am using ACA generic walls and doors for quick schematic room layouts.
    I use the sheet set manager to make sheet with views.
    All 2D linework is visible in the views, but the walls and doors  (AEC objects) do not appear!
    Please help.
    Dan
    Valued Mentor
    Re: Help - Walls and Doors not visible in viewports!
    02-08-2012 08:50 AM in reply to: dlbellotte
    Check what layers are turned on/off frozen in that viewport.
    Check cutplanes.
    See if Display Rep is same in viewport as in model space.
    I assume your templates are compatible for modelling and views sheets.
    Is it an x-ref - check the hieght x-ref is inserted at. (might not be 0 and still be correct).
    www.ausaca.blogspot.com
    Do you know all about the Roof Object? Learn it's secrets
    http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
    Active Contributor
    02-08-2012 10:40 AM in reply to: ntellery
    Thanks ntellery!
    It was the display rep
