• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    pogocomrules
    Finding the square footage.
    63 Views, 2 Replies
    02-05-2012 05:04 AM
    now i know this is possible because i did it once before with 2012 but now i can't remember how any suggestion would be appeciated.
         Kris
    Re: Finding the square footage.
    02-05-2012 02:17 PM in reply to: pogocomrules
    For the entire perimeter,  I find the simplest way is to draw a closed polyline, then enter List at the command line.    For individual rooms, you can use Spaces.
    New Member
    02-06-2012 01:16 AM in reply to: pogocomrules
    Two or more ways to accomplish the task:
    If you use the method to create a closed polyline, select the closed polyline object, right-click, choose Properties, scroll down the list and you should see the Area object properties.
    Second method is to use the BOUNDARY command to create a close polyline, select the closed polyline object, right-click, choose Properties, scroll down the list and you should also see the Area object properties.
    Third method is to use the HATCH command. Create any hatch pattern/solid hatch over the boundaries, select the hatch, right-click, choose Properties, scroll down the list and you should also see the Area object properties.
    Try it.
    Good luck!
    Cheers,
    Sim
