AutoCAD Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Finding the square footage.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
now i know this is possible because i did it once before with 2012 but now i can't remember how any suggestion would be appeciated.
Kris
Re: Finding the square footage.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For the entire perimeter, I find the simplest way is to draw a closed polyline, then enter List at the command line. For individual rooms, you can use Spaces.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Two or more ways to accomplish the task:
If you use the method to create a closed polyline, select the closed polyline object, right-click, choose Properties, scroll down the list and you should see the Area object properties.
Second method is to use the BOUNDARY command to create a close polyline, select the closed polyline object, right-click, choose Properties, scroll down the list and you should also see the Area object properties.
Third method is to use the HATCH command. Create any hatch pattern/solid hatch over the boundaries, select the hatch, right-click, choose Properties, scroll down the list and you should also see the Area object properties.
Try it.
Good luck!
Cheers,
Sim
