I recently started drawing house in 3D in AutoCAD Architecture 2013. Now I ran into few problems that the Elevation not generating properly, lines running through the house as well as the roof missing lines. But when I check in 3D model, everything seems correct. I tried 2 different ways to generate the elevations, unfortunately still not fixing the problems. Does anyone have any idea?
Attached is a screenshot of what my elevations look like.
Solved by leonlo13. Go to Solution.
Is it possible for you to post a drawing file marking the area of the elevation that has some lines missing?
Thank you to Laks, the problem fixed itself by refreshing it in AutoCAD Arcthitecture 2015. I was using 2013, and that was the issue.
