EPS to DWG
EPS to DWG
Message 1 of 13
EPS to DWG
Hi
I need help finding a program that will convert eps to dwg.  My goal is to scale my .eps image and insert into autocad to use.  I don't need to edit the image, just scale it.
I don't want the image to be rastor/blurry.  I would like to keep the nice clean image.  I've been reading a lot of forums/blogs but have yet found a solution.
Thanks!!
Replies (12)
Message 2 of 13
TerryDotson
If this is a one time shot (one file) email it to me dotson [at] dotsoft [dot] com.  I did one before by distilling it to a PDF then importing the PDF into AutoCAD (we have software for that).  In that case the results were crisp geometry, but it can depend on the source EPS.
Message 3 of 13
Adobe Illustrator can probably do that.
BT
Message 4 of 13
jcp
You could try Autodesk's free DWF Writer. Print to the DWF Writer and then attach the dwf in AutoCad.
Message 5 of 13
DWF writer... Very clever!
Message 6 of 13
It worked!  Thanks so much!  Another thread had a good idea as well, but this one is far far easier!!
Message 7 of 13
john-peter_lindberg
Observer
Observer
Hi! lets wake this thred up!
How do I open the eps-file in AutoCAD to be able to print it with the DWF-printer, or what am I missing?
Message 8 of 13
pendean
Community Legend
Community Legend
AutoCAD doesn't import or open EPS files.
Message 9 of 13
john-peter_lindberg
Observer
Observer
Ok, so I´ve to print from Adobe with the DWF-printer then?
Message 10 of 13
DWF writer is just too old to bother with in 2017. Last updated around July 2010 per the AutoDesk Readme. I tried to plot from PDF to DWF with it, it made a file but I couldn't open it with 2018 Design Review. Plus, if you wanted to plot from EPS to DWF with the DWF printer, you would still need a viewer...
A better way is to use a program called Inkscape (you could call it an open source Adobe Illustrator clone). Open the EPS with Inkscape, save as DXF. (you'll need to experiment with the save as DXF options a little to get the best results).
Then, just import DXF into AutoCAD.
Message 11 of 13
rbcastor
Observer
Observer
Inkscape worked well for converting .ai to .dxf, but it doesn't look like the current version will open .eps
Message 12 of 13
It works for me on Windows 8.1, 64 bit, Inkscape 9.2.1 64 bit (latest as of this reply is 9.2.2).
9.2.2 is a bug fix release, they shouldn't be removing any features. So if you're having issues you think might not have been reported yet (and a few minutes of free time), check your version number and notify the Inkscape development team.
You could also try an older version in the meantime, looks like they are good at making many previous versions available for download.
Message 13 of 13
cpennetti
I tried a few things listed in this post without success.  I then looked at it as attachment from my phone (Android P) and it opened up in the Adobe Reader app.  I could then save the eps to a PDF, and then PDFIMPORT in cad to get the linework I needed.
Just another thought.
I also had someone covert from AI to DXF, which turned out even better, but the workaround from my phone got me started.
