AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Drawing Scale Variable
16 REPLIES 16
Message 1 of 17
731 Views, 16 Replies
I would like to create a custom command for text and dims which uses the
Drawing Scale value to set the appropriate text height and dim scale. Does
anyone know how I can access the Drawing Scale value in a lisp routine? Any
help would be greatly appreciated!
George Wharton
16 REPLIES 16
Message 2 of 17
ADT 3
(defun SA:AecTextHeight (/ TH)
(setq TH (CDR (ASSOC 42 (dictsearch (cdar (dictsearch (namedobjdict)
"aec_vars")) "aec_vars_dwg_setup"))))
TH
(defun SA:AecScale (/ ds)
(setq ds (CDR (ASSOC 40 (dictsearch (cdar (dictsearch (namedobjdict)
ds
(defun SA:AecCurrentLayerKey (/ lk)
(setq lk (cdr (assoc 9 (dictsearch (cdar (dictsearch (namedobjdict)
lk
ADT 2
(setq TH (cdr(assoc 42 (entget(cdr(car(reverse(dictsearch (namedobjdict)
"AEC_VARS")))))))
TH
(setq ds (cdr(assoc 40 (entget(cdr(car(reverse(dictsearch (namedobjdict)
"AEC_VARS"))))))))
ds
(setq lk (cdr (assoc 9 (entget (cdr (car (reverse (dictsearch
(namedobjdict) "aec_vars")))))))
lk
CJ
"George Wharton" wrote in message
news:189357A97BBA3734BEA84193F012B4CB@in.WebX.maYIadrTaRb...
Any
> George Wharton
Message 3 of 17
Thanks CJ this worked great. I had to change (defun SA: to (defun c: and
then it worked fine. Where can I find more info on these "aec_vars"?
George Wharton
ADT2i
"CJ Follmer" wrote in message
news:B1C982FE14BF114B8DF615A1CB7681C6@in.WebX.maYIadrTaRb...
> ADT 3
> TH
> ds
> lk
> ADT 2
> "AEC_VARS")))))))
> TH
> "AEC_VARS"))))))))
> ds
> lk
> CJ
Does
> Any
> > George Wharton
Message 3 of 17
Will this work for ADT 2.0 as well?
Message 3 of 17
CJ
your SA:AecTextHeight funciton is missing a paren so it will not work.
Rob Starz
Plogv 3.0 & 2000 (plot logging) for r14 & 2000
***Enhancement Tools for Arch. Desktop *****
!!!!!Beta Testers Needed For DormerX!!!!!!!
http://www.stardsign.com/DormerXForm.htm
http://www.stardsign.com/main.htm
> ADT 3
> TH
> ds
> lk
> ADT 2
> "AEC_VARS")))))))
> TH
> "AEC_VARS"))))))))
> ds
> lk
> CJ
Does
> Any
> > George Wharton
Message 6 of 17
Not documented for Visual Lisp, but it is for VBA.
Cheers,
Peter Funk
API Product Manager
Building Industry Group
Autodesk, Inc.
Message 6 of 17
oops, the adt 2's were written more on the fly. thanks rob.
"Rob Starz" wrote in message
news:39DA26CB77C1F43C20AF54479242DF0A@in.WebX.maYIadrTaRb...
> CJ
> Rob Starz
> > ADT 3
> > TH
> > ds
> > lk
> > ADT 2
(namedobjdict)
> > "AEC_VARS")))))))
> > TH
(namedobjdict)
> > "AEC_VARS"))))))))
> > ds
> > lk
> > CJ
the
> Does
routine?
> > Any
> > > George Wharton
Message 6 of 17
oh this question should get rob started again with ADN? :_)
actually , we found out by analysis.
change a setting and see what gets changed.
it is not documented, unless you belong to the club!
> George Wharton
> ADT2i
> > ADT 3
> > TH
> > ds
> > lk
> > ADT 2
> > "AEC_VARS")))))))
> > TH
> > "AEC_VARS"))))))))
> > ds
> > lk
> > CJ
> Does
> > Any
> > > George Wharton
Nauman M
CAD Bazaar
Need to easily Navigate to your Custom Content Folders?
Need Autolayering for Dimensions without going through Design Center?
Download the updated ADT Tools for ADT 2 & 3 at
http://www.cadbazaar.com
Message 6 of 17
yes
Nauman M
CAD Bazaar
Message 10 of 17
No Documentation! Thats great.
Thanks Nauman M
"Nauman M" wrote in message
news:3B7AB9D3.2C7B41CE@email.com...
and
> > George Wharton
> > ADT2i
> > > ADT 3
> > > TH
> > > ds
> > > lk
> > > ADT 2
(namedobjdict)
> > > "AEC_VARS")))))))
> > > TH
(namedobjdict)
> > > "AEC_VARS"))))))))
> > > ds
> > > lk
> > > CJ
the
scale.
> > Does
routine?
> > > Any
> > > > George Wharton
> Nauman M
> CAD Bazaar
Message 10 of 17
instigator!!!!
Rob Starz
Message 10 of 17
UNFORTUNATELY i was not able to get to it after translating vba code to
vlisp either. It shows error when I get the listing.
(see my Vlisp /activeX post earlier.)
PS:
Though a good way to look at it is to get the dump of ActiveX
properties and compare it with the DXF properties.
and build a chart for yourself.
> Cheers,
> Peter Funk
> API Product Manager
> Autodesk, Inc.
Nauman M
CAD Bazaar
Message 13 of 17
Not Found
The requested URL /DormerXForm.htm was not found on this server.
there you go , beta tested this for you already!!!
Rob Starz wrote:
> instigator!!!!
> Rob Starz
Nauman M
CAD Bazaar
Message 14 of 17
I clicked on the link and the page opened. You need to test on a computer
not a calculator.
Rob Starz
news:3B7AD10E.79FC2AF1@email.com...
> Not Found
> Rob Starz wrote:
> > instigator!!!!
> > Rob Starz
> Nauman M
> CAD Bazaar
Message 15 of 17
http://www.stardsign.com/DormerXForm.html opens not htm. on my
calculator...
should be html not htm, ???
> not a calculator.
> Rob Starz
> > Not Found
> > Rob Starz wrote:
> > > instigator!!!!
> > > Rob Starz
> > Nauman M
> > CAD Bazaar
Nauman M
CAD Bazaar
Message 16 of 17
Ok...this is freaky.
for some reason there are 2 files on my server htm and html. I made htm and
the htm link works for me. i don't know why html is there. I guess which
ever one works for you is great. They both work for me. I will be deleting
the html one.........OH...I know why.
My server host had to change all htm files to html for the counter to work.
I forgot they did that. I will leave the html one there and fix my link
Rob Starz
news:3B7ADAAA.6E4DE2D8@email.com...
> calculator...
computer
> > not a calculator.
> > Rob Starz
> > > Not Found
> > > Rob Starz wrote:
> > > > instigator!!!!
> > > > Rob Starz
> > > Nauman M
> > > CAD Bazaar
> Nauman M
> CAD Bazaar
Message 17 of 17
my calculator works fine!!
> Rob Starz
> > calculator...
> computer
> > > not a calculator.
> > > Rob Starz
> > > > Not Found
> > > > Rob Starz wrote:
> > > > > instigator!!!!
> > > > > Rob Starz
> > > > Nauman M
> > > > CAD Bazaar
> > Nauman M
> > CAD Bazaar
Nauman M
CAD Bazaar
”Boost
