• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture
    Member
    Double Swing Doors
    328 Views, 6 Replies
    10-02-2012 06:48 AM
    Greetings,
    Having just recently switched employers I'm trying to get some "old" styles back . One of those was a door showing a double swing. I've never had the need to customize but am in a situation now where I will need to start doing so. It seems as though showing a door with a double swing would be an easy task but I'm not even sure how to start.
    Are there any simple tutorials or any suggestions were to begin?
    Please use plain text.
    Re: Double Swing Doors
    10-02-2012 08:17 AM in reply to: DDING
    I would suggest using a custom display block to add the dashed representation of the door swing.
    David Koch
    Distinguished Mentor
    10-03-2012 06:59 PM in reply to: DDING
    A very easy cheat way to do this is simply add another door over the top. Quick and dirty if it's just a one off.  Just make sure it doesn;t get scheduled.
    www.ausaca.blogspot.com
    Do you know all about the Roof Object? Learn it's secrets
    http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
    10-04-2012 10:53 PM in reply to: DDING
    If you mean "double swing" to be say opening 90 degrees forward and back, you can nominate a predefined one in design rules - communicating door.
    Change opening % if you want to open more than 90 degrees.
    Member
    10-05-2012 04:47 AM in reply to: croc49
    The communicating style is the closest to what I need, now the next problem is for a double door.
    10-05-2012 05:08 AM in reply to: DDING
    Double dhung will work, although you'll probably have to compromise hidden lines.
    Member
    10-05-2012 05:12 AM in reply to: croc49
    Thanks, that's what I was looking for. I can live without the hidden lines.
