• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Valued Mentor
    Door Schedule will not place 2nd level below 1st?
    105 Views, 2 Replies
    01-07-2010 04:51 AM
    I had this working properly and now it isn't working again. I have a project that has A100 and B100 Areas. The "A" area has a second floor. I want the A200 Area doors to come after the A100 and B100 doors. I placed quote marks around the data it is pulling from the PSD and still nothing.
    Ideas on what I am missing?
    Thank you for the help.
    Please use plain text.
    *Expert Elite*
    Re: Door Schedule will not place 2nd level below 1st?
    01-07-2010 06:20 AM in reply to: Caddman13
    How are your room numbers created?
    --Are you manually typing in the entire room number into one manual property?
    --Are you deriving the "A" or "B" from an automatic Project Property referencing the Division (if using Project Navigator), or from a separate manual property (if not using Project Navigator)?
    --Are you deriving the numeral for the floor ("1" or "2" in your example) from a separate property (automatic Project Property referencing the Level property if using Project Navigator or a manual property otherwise)?
    The reason I ask is that the easiest way to get a Schedule Table to sort the way you want would be to include an additional, hidden column that indicates the floor level, and sort on that column first, then sort on your room number column. That would get all spaces on the first floor up top, followed by those on the second floor.
    If you are just entering the entire room number in one manual property, you may want to consider breaking it up into components and then useing a formula property to concatenate them into the room number. The alternative would be to set up a formula property to "extract" the floor level information from the room number, and use that property as the initial sorting property in the Schedule Table. If your room numbering follows consistent rules for the letter prefixes and floor level indicators, it would not be too hard to extract the floor level. It would be easier, of course, to start out with separate values.
    David Koch
    Valued Mentor
    01-07-2010 11:30 AM in reply to: Caddman13
    David,
    Thank you again for helping me out. I added a PSD for DoorLevel that reads the Project Nav Level and bingo.
    I was trying everything else I could think of but that.
    Thank you again.
