AutoCAD Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Design Center
Options
- Highlight
- Email to a Friend
181 Views, 3 Replies
05-23-2012 06:42 AM
Why is the design center not coming on screen. When I press the button, the command says adccclose
Re: Design Center
Options
- Highlight
- Email to a Friend
05-23-2012 11:08 AM in reply to:
crocra
In your command line type DC and see if that helps...
Re: Design Center
Options
- Highlight
- Email to a Friend
05-24-2012 05:42 PM in reply to:
crocra
No, it does not work, nothing happened. In the ribbon insert, when I press the button Design center the command says:adcclose
Re: Design Center
Options
- Highlight
- Email to a Friend
05-25-2012 06:37 AM in reply to:
crocra
ADCCLOSE closes design center: so open CUI command, navigate to the button you pushed and see if the macro code there has been changed to only do the 'ADCclose' function.
Otherwise, did you recently change from a dual-screen setup or someone take away an external or additional monitor you used to use? It's probably still parked over there and you cannot find it to use it.
