Hello everyone:
I need some help with a custom command (aec content). I created a finish schedule tag to follow my office standard. The problem is that when I start using it says that it can not open the Propertyset.dwg, If I use the tag from ADT it works fine, but not mine.
The command is as follow:
_AecAnnoScheduleTagAdd PropertySetDefs.dwg _SYMBOL IDEAS_FIN_LABEL_TAG _LEADER none _DIMSTYLE T1-FULL
What is wrong with it?
