AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Creating AEC Double Acting Door Style for ADT3.3
2 REPLIES 2
rpatters
353 Views, 2 Replies
Does anybody know how to create a double acting door style that ADT3.3 will recognize as a AEC style that can be modified once installed into a wall? I had somebody create a door block to create this type (for ADT2i) of I was looking to use, but I can not modify the swing the leaves the way they are show graphically. This door style is not recognized in ADT3.3 it just shows the door jamb but doors. Please help!
Randy Patterson Giant Food Stores, LLC.
2 REPLIES 2
in reply to: rpatters
Randy,
Are you looking for something different that the
standard ADT "Double-Dhung" door type?
Peter Funk
API Product Manager
Building Industry Division
rpatters
Peter,
NO! That door only shows door wing on one side of the frame.
I work for a supermarket, which uses high impact double acting doors; swing both ways and graphically show the swing on both sides of the frame. (With one side of the door style looking like a regular door & the other side being shown like dashed door and swing) I had Reid Addis (ADT & SoftDesk Trainer formally with Synergis Technologies) create this type of door style for our ADT2i. He created the door by adding a door block to the door style, which is okay, but it could not be manipulated to change the swing from original setting of 90 degrees!
I could send you the door style via email if you would like to see what Reid Addis created.
Is this something that can be created in ADT3.3 and going forward?
Randy Patterson
Carlisle, PA
”Boost
