AutoCAD Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Can't find PGP file
- Highlight
- Email to a Friend
i am using AutoCad Architecture 2009 in non-ribbon format and want to edit my PGP file. For some reason I do not have "Tools>Customize" on my menu lines anywhere. When I search thru the hard drive, the only place I find any PGP files are in an UserDataCache. Can anyone tell me where the real PGP file should be? If it makes a difference, this is a Windows 7 64 bit system.
Re: Can't find PGP file
- Highlight
- Email to a Friend
For ACA 2009 on Windows Vista (Home Premium), standalone installation using default file locations, my ACAD.pgp is located here:
C:\Users\David\AppData\Roaming\Autodesk\ACD-A 2009\enu\Support
Substitute your user name for "David". I believe that the folder structure for Windows 7 is similar to Windows Vista (have not upgraded my desktop to Windows 7 yet, so I do not know for certain), but if you customized file locations, your ACAD.pgp file may be elsewhere.
- Highlight
- Email to a Friend
Thank you David, that's where it is. I doubled check, but it still won't appear in a search either for the entire name or partial (acad*.*, *.pgp, etc.). Must be something in Windows 7...I don't think the pgp file is hidden.
- Highlight
- Email to a Friend
In Vista, the C:\Users\[UserName]\AppData folder is hidden, which would hide all folders and files below it as well. I assume that you can turn on the display of hidden folders in Windows 7, like you can in Vista or XP. Doing so should make your search return the location of the PGP file - unless Windows 7 requires that you explicitly specify that hidden files and folders be searched.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Thanks Dean!
