• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    Can't Open AutoCad 2011
    85 Views, 2 Replies
    01-03-2013 12:43 PM
    I am running AutoCad 2011 32 bit and suddenly, for the first time I can't get it to open.  I have run Repair and Reinstall, and all sorts of diagnostics to no avail.  Can anyone provide me with a solution to this problem?
    Ray Cox
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Can't Open AutoCad 2011
    01-03-2013 05:41 PM in reply to: RAYCOX5805
    did you try simply restarting your pc when it first happened?
    or a Windows System Restore?
    this started mid workday, or has there been an overnight or more time between now and when it last worked? or did you install or uninstall or upgrade or downgrade something on that PC?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    01-04-2013 02:22 AM in reply to: RAYCOX5805
    which OS are used ?your system fullfill the requirement are needed to autocad 2011.
