• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Accepted Solution
    CREATEHLR is crashing AutoCAD Architecture
    280 Views, 2 Replies
    06-09-2012 04:44 AM
    Whenever I select more than one or two simple objects in AutoCAD Architecture 2013 and try the CREATEHLR command, CAD crashes.
    This is true from the Model tab, other tabs I've set up, and regardless of view.
    I've audited the drawing.
    I've done an installation repair.
    I've been sure to use the ACA profile.
    The error message is:
    Fatal Error:  Unhandled Access Violation Reading 0x000 Exception at e3d57cb6h
    Please use plain text.
    Product Support
    LanceEdwards13
    Re: CREATEHLR is crashing AutoCAD Architecture
    06-14-2012 12:16 PM in reply to: Impact
    There is a known issue with the Section and Elevation tool in ACA 2013 that has been corrected by the hotfix below. This issue has also affected the CREATEHLR copmmand.
    http://usa.autodesk.com/getdoc/id=DL19248702
    Install the hotfix and report back.
    Lance Edwards
    Product Support Technical Specialist
    Product Support
    Autodesk, Inc.
    06-14-2012 01:18 PM in reply to: LanceEdwards13
    Thanks, Lance!
    That did the trick.  I tested it several times with no errors, crashes or problems.
    Kudos!
    - Dave
