We have AutoCAd Architecture 2012 install in a lab environment. My issues are
1. The ribbon willl disappear on some of the PC's. There is no pattern to the issue and will happen when performing the smallest task in AutoCAD
2.The ribbon does not have the build command and I thought I had figured out a way to get it back by typing cuiload at the command and then unloading any customization groups that are loaded then browse and load ACAD.cuix which then loads the build command. This does not always work
3. I then have an issue on some occasions when the Build Panel works that when I select Tools -> Design Tools on the Build panel I get an error saying something like it cannot find design.
I have applied SP1 but does not seem to make any difference
These issues are happening in a lab environment it is very difficult to pin down exactly what is going on. It can often happen that the issue will occur on one PC and not the other.
Has anyone else come across these issues
