AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Batt Insulation Lisp Problem.
8 REPLIES 8
Message 1 of 9
339 Views, 8 Replies
I have found a lisp routine in customer files and it works great. My
problem is that it sets osmode to 0. Is there a way to set it back to the
way I had it? I not sure how to make this work in the lisp routine file.
I've tried a few different things but I can't figure it out. I'll post the
file I use in CF, if someone wouldn't mind taking a look at it. Or does
anyone have a lisp routine that does what I want!
Clint P. Ryan
Alexander + Kienast
E: clintr@aktexas.com
8 REPLIES 8
Message 2 of 9
The customization group is the best place for these types of questins but
the answer is yes ...
Add to the beginning...
(setq OSM(getvar "osmode"))
At the end....
(setvar "osmode" OSM)
Message 3 of 9
Oh I also get the following error, it doesn't seem to create a problem for
me, at least I don't see one. Except the osnap problem.
Command: batt
Enter start point (Left to Right)
Enter end point.
Enter insulation thickness. <3.5">
; error: no function definition: DGTR
Clint P. Ryan
Alexander + Kienast
"Clint P. Ryan" wrote in message
news:558057396A48572A59A9ACA8B2AE499D@in.WebX.maYIadrTaRb...
the
> Thanks,
> Clint P. Ryan
> Alexander + Kienast
Message 4 of 9
Before the LISP routine sets OSMODE to 0, store the current value in a variable, preferably a local one, then restore it at the end, after the insulation is drawn.
(setq curosmo (getvar "OSMODE")) ; Store current value.
(setvar "OSMODE" curosmo) ; Reset initial value.
If you want to be really clever, you would have an error trapping routine that would be able to restore the values should the routine crash before the value is reset, but that is one area (of many) that I have not mastered.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
Message 5 of 9
Clint,
As Chip said in the ADT newsgroup the best place to get support for these
types of question is from the customization group.
The dgtr is an added routine that CJ has called separately in another
program, it essentially changes degrees to radians. Please check customer
files for a modified version of CJ's routine.
-Beau
news:6DDC782F3137F0D01BBD899DD01285AA@in.WebX.maYIadrTaRb...
> Command: batt
> Enter end point.
> Clint P. Ryan
> Alexander + Kienast
the
file.
> the
> > Thanks,
> > Clint P. Ryan
> > Alexander + Kienast
Message 6 of 9
Clint,
Don't you have ADTcadPac? There is a routine to do batt insulation for
walls and an undocumented command.
Type BATTINSUL and select the points.
Let me know if you have any questions.
Rob Starz
| president / dreamer | director
| Stardsign cad solutions | Autodrop , llc
| 352.263.3786 | www.autodrop.net
| AEC Designer / Consultant / Developer
| Autodesk Architectural Desktop:
Tools: www.stardsign.com
Tech Support: www.stardsign.com/support.htm
Bring the power of i-drop into AutoCAD with i-dock
(www.stardsign.com/idock.htm)
Message 7 of 9
RTFM?? 😉
Reid M. Addis
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
"Rob Starz" wrote in message
news:27DA8C67943475D12E899A3864889FDA@in.WebX.maYIadrTaRb...
> Clint,
> Rob Starz
Message 8 of 9
What does that mean? I have an idea...before you answer. what does the
last line of Clint's post say?????? think about it.
Rob Starz
Message 9 of 9
Thanks for updated file, that works perfect, Thanks!
Clint P. Ryan
Alexander + Kienast
"Beau Turner" wrote in message
news:3EF586C362E38C5134B86AAC85C41A88@in.WebX.maYIadrTaRb...
> Clint,
> -Beau
for
> > Command: batt
> > Enter end point.
> > Clint P. Ryan
> > Alexander + Kienast
> the
> file.
post
> > the
does
> > > Thanks,
> > > Clint P. Ryan
> > > Alexander + Kienast
”Boost
