• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Alfredo_Medina
    Re: AutoCAD Architecture 2010 - 32bit verses 64bit
    12-13-2009 06:25 AM in reply to: JJKennedy03
    Another thing to keep in mind is that if you are upgrading customization content, you need the new versions of your customization tools, if you use these, of course:
    a 64 version of DOSLIB ( DOSLib18x64.arx ) at http://download.rhino3d.com/download.asp?id=doslib
    a 64 version of ObjectDCL ( ObjectDCL-ARX64-7.2.0-Setup.msi ) at http://www.objectdcl.com/en/arx.html
    a 64 enabler of VBA ( AutoCAD VBA module 64-bit ) at http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
    Also, after installing the VBA enabler, the old VBA routines have to be checked one by one. Most of them will work, but some lines of code might need to be changed. Some of them might cause AutoCAD to have a very slow performance while saving. It is recommended to migrate these routines to the new VSTA programming tools.
    The very old, good, and simple AutoLisp will still work, as always.
    Alfredo Medina
    info@planta1.com
    http://www.planta1.com
    Planta1 Revit Online Consulting | info@planta1.com
    Please use plain text.
    Valued Mentor
    12-13-2009 10:44 AM in reply to: JJKennedy03
    If hard drives do make that much differance, have you considered solid-state drives? I've seen some impressive speed tests.
