• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture
    New Member
    atrium
    Array command
    180 Views, 5 Replies
    12-11-2011 05:54 AM
    Please, answer my questions!
    The Array command does not work in the same way like in previous versions and I find it difficult.
    Also the snap mode does not work propel y when no command is in process and no object is activated.
    The second question I already asked some months ago and still haven't got an answer.
    Stoycho Popov
    Please use plain text.
    *Expert Elite*
    Re: Array command
    12-11-2011 06:40 AM in reply to: atrium
    Are you using ACA 2012?  If so, have you installed Service Pack 1?  Service Pack 1 added a command called ARRAYCLASSIC, which runs the "old" version of the ARRAY command, for those who prefer that.
    When you say that snap mode does not work, are you talking about having the cursor only move to SNAP points, even when no command is active?  If so, Service Pack 1 added a system variable called SNAPGRIDLEGACY.  Set it to 1 to restore the previous behavior of always snapping to SNAP grid points.
    A listing of the other issues addressed by Service Pack 1 can be found in this blog article, or in the ReadMe that can be downloaded from the same page on the Autodesk site as the service pack.
    David Koch
    New Member
    atrium
    Re: Array command
    12-13-2011 02:20 AM in reply to: atrium
    Thank You very mach! I'll try this.
    Christmas greetings!
    Stoycho Popov, architect
    Product Support
    Re: Array command
    01-18-2012 05:55 AM in reply to: atrium
    I wanted to check in and see if the previous suggestion from David helped resolve your inquiry.  If not please let us know so we can actively aide towards resolution within the community moving forward.  Thank you and we look forward to your update.
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    Re: Array command
    02-10-2012 09:23 AM in reply to: atrium
    ArrayClassic fixes the issue. BUT.... why dump the command anyway? Autodesk seems to change things just for the sake of change. Plenty of examples of "improvements" which lose the abilities of prior commands, including locations of support files, commands, door insertion points, etc.
    Now i have to amend the command alias to reference the old command. This as i am being prompted to renew my subscription, which will likely ellicit a "new and improved" version for 2013.
    Product Support
    Re: Array command
    02-13-2012 02:05 PM in reply to: BrianManthey3915
    Thank you for your post.  In this case our development team is constantly looking for feedback about the product/features, current and future.  The best means for expression of these concerns is to utilize the product feedback link below.  I urge everyone who may read this post to quickly fill out this link below and send their feedback directly to the team for review and consideration in current and future release of the software.  This link is one of the most powerful (but underutilized) links we supply and offer to our customers.  This gives you the user a direct voice and connection to solicit this feedback and any concerns you may have about the current or future products.  Thank you.
    Product Feedback Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    General Autodesk Feedback link:  http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1073231
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
