• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Architecture loads as Acad
    128 Views, 2 Replies
    04-29-2012 06:05 AM
    I've downloaded Arch as part of Factory design suite, it looked ok until  I clicked on wall or door when the command was recognised but nothing happened at the cursor.  Unable to correct it I reinstalled via control panel and now it calls itself Architecture 2013 but has Acad interface and workspaces, no architecture features at all.  In addition Acad which is part of Mechanical now calls itself Architecture but still loads as Acad, what is happening?  Mechanical has remained unchanged.
    Regards
    Tony
    Please use plain text.
    Re: Architecture loads as Acad
    04-29-2012 08:25 AM in reply to: tony.birch4
    What profile are you running?  ACA can be installed with an AutoCAD profile that then runs "as AutoCAD" (no AEC modules are loaded, so no ACA commands are available).
    David Koch
    04-29-2012 09:13 AM in reply to: David_W._Koch
    That was it, I set Architecture as current and problem solved.
    Many thanks
    Tony
