The problem is that I have a react that will run after the wall add command.
This function parses through the walls added. All the walls I have contain
sched data that should be automatically attached. I use the code
Set cPropSets = scheduleApp.PropertySets(objSelSet.item(ObjCounter)) but i
get no shchedule data. even after i go and grip click the Edit Schedule
Data and there is not schedule data attached. I am using the default
unedited Imperial template. I can verifythe ObjSelSet.item is an AecObject
but a whatch on this with the sceduleApp shows nothing.
Am I doing something wrong?
Rob Starz
Plogv 3.0 & 2000 (plot logging) for r14 & 2000
***Enhancement Tools for Arch. Desktop *****
!!!! DormerX out in Sept !!!!
http://www.stardsign.com/main.htm
"Peter Funk - Autodesk, Inc"
wrote in message
news:06CBBBEF91D0DA1B1460A7C2D465D05C@in.WebX.maYIadrTaRb...
> Rob,
> If the object has schedule data attached, then you can ask the property
for
> it's "value" The value will either be something entered, or will be
> "automatically" be generated from the object. Is that what you are looking
> for?
> Cheers,
> Peter Funk
> API Product Manager
> Building Industry Division
> Autodesk, Inc.
> "Rob Starz" wrote in message
> news:A3A6DD111BFB9E8D889F52A490481F60@in.WebX.maYIadrTaRb...
> > Has the Automatic Schedule Data been exposed in ActiveX? I have some
data
> > that I want to use with an application but the data needs to be attached
> so
> > i can react to this data.
> > Please say yes...I don't want to resort to puting the information in the
> > Wallstyle Description area.
> > Rob Starz
