• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    New Member
    KilroyJr
    Acad Architecture 2011 extremely slow shading and 3d orbit.
    577 Views, 8 Replies
    03-08-2011 11:07 AM
    We have 20 brand new workstations that are running Architecture 2011 and it's extremely slow to change visual styles, regen, and 3d orbit. Here is what we are running.
    HP Z400 Workstation
    Intel Xeon quad @ 3.07
    6gb Installed ddr3
    Windows 7 64 Pro
    NVIDIA Quadro 4000 with latest driver updates
    I tried to install the Nvidia autocad performance driver and got the message "No application found for which a performance driver can be installed or upgraded."
    Any Ideas, please help...
    Charlie
    Active Member
    Re: Acad Architecture 2011 extremely slow shading and 3d orbit.
    03-31-2011 06:38 AM in reply to: KilroyJr
    We are experiencing the same problem with the latest workstations:
    Dell T5500
    Dual Six Core Processors 2.93GHz
    24GB RAM
    Windows 7 64 Pro
    2 x 146GB hard drives
    NVIDIA Quadro FX 4800
    We tried Autodesk certified driver, the latest nVidia driver and the Performance Driver for AutoCAD 2011 with no luck !!!
    The crazy thing is that we can 3d orbit the same model without problem on older workstations !!!
    Waiting to hear back from Autodesk.
    Contributor bec
    07-20-2011 07:12 AM in reply to: mawlsam
    us too....  how hard can it be to reply...  where is pedro...  lol
    New Member
    TeeHokken
    02-07-2012 10:20 PM in reply to: KilroyJr
    I have the same problem with HP 8760 Workstation, Quadro3000m.
    Could you learn anything how to solve it?
    Thanks.
    Valued Contributor
    02-09-2012 09:25 PM in reply to: KilroyJr
    just something to try. Turn off the cube and place the View toolbar back on you desktop. Use the toolbars to set shademode. I have a Dell T7500 with dual quad core xeon processors and 6gb ram and I was having the same problem. With the cube it was taking about 1-2 minutes to switch view direction and switch between layout and model space. After turning off the view cube  and adding the toolbars back in it went to about 2-3 seconds.
    Hope this helps.
    Joe
    Contributor bec
    02-13-2012 09:19 AM in reply to: jliston
    I shall be Pedro for a bit...  Autodesk doesnt care or know why...  We have had this issue for a while now...  Quad Core 16GB ram should not be this slow...  Sketchup flows better than this does...
    Active Member
    02-13-2012 09:28 AM in reply to: KilroyJr
    We found that this issue happens when the application shortcut has Compatability option to run as different operating system, e.g. Windows Vista on Windows 7.
    New Member
    TeeHokken
    02-13-2012 07:50 PM in reply to: KilroyJr
    No no... It's not it. I'm not in compatibility mode but still too slow. God **** Autocad. But 3dsMAX is fine. No problem.
    New Member
    stevem
    02-15-2012 12:29 PM in reply to: KilroyJr
    Same problem with MEP 2012 on dual core xeon 3.07, 8GB RAM, NvIDIA 2000
