• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    AEC Polygons Again
    83 Views, 3 Replies
    03-14-2012 06:51 AM
    So, trying to create a masing polygon for a callout bubble and the polygon changes from curved surfaces to straight segments when I complete the circle.  If I leave a portion of the polygon straight the mask remains curved.  So I made 2 halves of the bubble to mask the entire circular bubble.  If I merge the polygons they become straight segments.
    Does anyone have a solution or is this the only workaround?
    Gary
    Please use plain text.
    Product Support
    LanceEdwards13
    Re: AEC Polygons Again
    04-12-2012 12:37 PM in reply to: gary
    Have you found a solution to your problem yet? Can you post a quick sample file of the issue so that we may take a look?
    Lance Edwards
    Product Support Technical Specialist
    Product Support
    Valued Contributor
    04-12-2012 02:08 PM in reply to: gary
    Gary,
    I'm not sure how you're going about it but I use circular masking polygons and make them by creating a circular polyline (made by splitting a circle, mirroring, and converting to a polyline) and then converting to an aec polygon.
    John
    John W. Mumaw
    Timber Frame Designer
    Lost Bent Woodworking & Design
    Valued Mentor
    04-12-2012 05:28 PM in reply to: gary
    If it plots as a circle then-
    Have you checked the FACETRES and VIEWRES settings?
    Do you have a visual style set which could affect the appearance?
