• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Member
    ACA2009 Project Navigator Batch Plot Issue
    61 Views, 1 Replies
    06-19-2008 01:58 AM
    The company i work for are in the process of moving from ACA2008 to ACA2009. We are having a problem with the project navigators batch plot facility. We had this working perfectly for ACA2008. We seem to be able to send single plots to plotters ok, whether using page overides or original setting. We can batch plot DWF's. But we cannot send more than one sheet to a plotter at a time. No error occurs, the plots appear to go ok, but nothing ever comes out of the plotter. We were able to do this ok with ACA2008!!!
    Is this a known issue?
    thanks
    Chris
    Please use plain text.
    Active Member
    Re: ACA2009 Project Navigator Batch Plot Issue
    08-29-2008 07:36 AM in reply to: chrismackay
    well...it is an known issue for me.
    i got batchplot working for "publish to plotter". The problem was solved by making a new pc3 file for all printers and plotters
    The "plot to alternate page setup" batchplot is still not working.
    (i checked the template several times but everything looks fine)
    Cor
