• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    ACA Dimension Overrides not working - 2013
    150 Views, 2 Replies
    04-30-2012 06:14 AM
    Has anyone experienced this with the new 2013 version?  I am trying to override a dimension to provide a +/- at the end of one ACA dimension.  I added the override, but it is not showing up - even after a regeneration...
    Anyone confirm this on their 2013 version or is it just me...
    Dave
    Please use plain text.
    Product Support
    Re: ACA Dimension Overrides not working - 2013
    05-01-2012 12:03 PM in reply to: dtdesign
    How are you applying this override?  I was able to go into the properties and override the value along with "+/-" within the measurement itself in ACA2013.  Are you using a custom style and would it be possible to see a copy of this DWG with this example for testing and viewing?
    Michael Bussiere II
    Support Specialist
    Product Support
    Active Contributor
    05-01-2012 12:21 PM in reply to: dtdesign
    It was only apparent on one particular ACA string - it worked fine on the rest.  I just deleted that string and recreated it and was able to apply the over-ride.  Must of been just a bug with that one string - the problem hasn't shown up on any other strings since...
    Chalk it up to a buggy dimension string.
