• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Valued Contributor
    twox2
    ACA 2013 ceiling issue
    113 Views, 2 Replies
    10-12-2012 10:01 AM
    We are on ACA 2011 and created a ceiling plan. Sent it to a consultant that is on ACA 2013.
    The file was saved down, but when we try to make a new ceiling or copy an existing grid, we get the following:
    Command: _AecCeilingGridAdd
    Command not allowed because drawing contains objects from a newer version of
    this application.
    how to fix?
    thanks
    Please use plain text.
    Valued Contributor
    twox2
    Re: ACA 2013 ceiling issue
    10-12-2012 10:14 AM in reply to: twox2
    I am getting into the file more and there are more problems.
    The detail component manager, display manager, anything on the build ribbon does not work.
    I have ACA 2011 open with 2 different files.  I switch to the other file and everything works, but when I switch to the one that was ACA 2013, none of these commands work.
    10-13-2012 07:46 AM in reply to: twox2
    There was a file format change in the 2013 release, just as there was with the 2010, 2007 and 2004 releases.  If you open a file created in one file format in a release that uses a later file format, the AEC objects are "promoted" to the new file format.  If you then save that file in the later release, there is no way for earlier-format releases to make use of AEC objects, even if you "save back" to the earlier format.  In fact, if your version of ACA detects future versions of AEC objects, all of the AEC modules will be disabled for that file, and you will not be able to even create new ones.
    With proxy objects turned on by the 2013 user, you could open and view the file in an earlier release, but you would not be able to edit AEC objects or run AEC commands.  The 2013 user could EXPORT the file to the file format you use (2010, for ACA 2011), but that would explode the AEC objects to AutoCAD primitives.
    Bottom line, if you need to share files with a team, all team members need to be using releases of the same file format.
    David Koch
