• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    New Member
    Re: ACA 2013 - Elevation Bug?
    04-23-2012 09:56 AM in reply to: Draftdoug5610
    Oh wow I have the same problem. glad I found others are running into it to. Tooks me weeks just to find the right forum. Hope this is resolved!
    Please use plain text.
    Member
    Herman
    04-23-2012 01:37 PM in reply to: pntrstthm
    Autodesk have sent me a hotfix that has solved the problem.
    Member
    04-23-2012 03:00 PM in reply to: Herman
    Herman,
    Can you post the link? Could not found it in update section.
    tks
    Member
    Herman
    04-24-2012 02:54 AM in reply to: AbilioLopesAlmeidaJr.2603
    The hotfix was with a responce from my subscription Autodesk support team.
    I'm not sure if I can post it on this site.
    Member
    Herman
    04-24-2012 02:57 AM in reply to: AbilioLopesAlmeidaJr.2603
    I would have expected to find it in "AutoCAD Architecture Services & Support" updates & downloads but it is not there at this time.
    Member
    Herman
    04-24-2012 03:00 AM in reply to: AbilioLopesAlmeidaJr.2603
    I think the Autodesk support team will know what operation system hardware you are using.
    Member
    04-24-2012 07:26 AM in reply to: Herman
    Herman,
    I am using windows 7, 64 bits. Are you using the same? I realy need this fix as soon as possible.
    tks!
    Active Contributor
    04-24-2012 08:07 AM in reply to: hugh_compton
    Post the fix, post the fix, post the fix.... come everyone now....
    Member
    04-24-2012 10:51 AM in reply to: pntrstthm
    dan
    Active Member
    04-24-2012 11:11 AM in reply to: hugh_compton
    it's been a month since the original post and still no fix???
