• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    crocra
    Accepted Solution
    ACA 2011 Interfaces
    151 Views, 3 Replies
    07-24-2011 10:30 AM
    When I launch the program ACA 2011 the interfaces are not shown properly i.e Home ribbon: Build, Transparency, inquiring, Section & elevation, Details, Panels are missing. Instead are shown Panels more related to Autocad itself. Same problem occurs with all other Ribbons. Worst than that Contextual Ribbon Tabs do not appear when I click on a wall.
    Can someone help me?
    Thank you
    Please use plain text.
    Product Support
    LanceEdwards13
    Re: ACA 2011 Interfaces
    07-25-2011 07:28 PM in reply to: crocra
    Chances are your CUI is set to the AutoCAD default CUI (ACAD.CUI). In AutoCAD Architecture it should be set to ACA.CUI. Type CUI on the command line and hit Enter. Make sure at the top of the main customization pane it is set to ACA.CUI.
    Lance Edwards
    Product Support Technical Specialist
    Product Support
    Autodesk, Inc.
    crocra
    07-26-2011 08:26 AM in reply to: LanceEdwards13
    You are right! Now, how can I set the customization pan from Acad.cuix to Aca.cui. Please tell me step by step. Thank you
    Product Support
    LanceEdwards13
    07-28-2011 09:21 AM in reply to: crocra
    It is actually a little easier to show you in a video than step by step. Attached is a quick video in the link of the items you should check to make sure ACA is pulling the right CUI.
    http://screencast.com/t/ctwH8BcpBy
    Lance Edwards
    Product Support
    Autodesk, Inc.
