• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Contributor
    ACA 2011 Block selection slow
    408 Views, 5 Replies
    01-09-2011 01:20 AM
    Hi All,
    I'm having a strange problem with ACA2011
    Selecting blocks is very slow, I click on any block (or select it in a window) and there is a 5 (or so) second pause.  However, I can then select some random number of blocks and other objects (5 to 20?) without issue only for the delay to return at some point.
    I have done some searching around and have turned off
    Layer Pallets
    Dynamic input
    3d object snap
    Dynamic input
    Lineweights
    Transparancy
    Selection Cycling
    I also ignore hatch objects
    Interestingly enough it does not seem to matter how large or small the drawing is, It acts the same way even if the only object in the drawing is a single block.
    My system
    ACA 2011 x64 with the SP applied
    Windows 7x64
    Dell M4500, 8 GB RAM, I7820QM, 64 GB SSD, 500 GB 7200 RPM drive, Quadro FX 880 M video card.
    Any ideas?
    Please use plain text.
    Active Contributor
    Re: ACA 2011 Block selection slow
    01-09-2011 03:24 AM in reply to: sgrinavi
    EDIT: Just noticed that I have a similar lag issue with XREFS
    Active Member
    03-02-2012 06:10 AM in reply to: sgrinavi
    any comments?
    People? Please somebody can answer?
    Active Contributor
    03-02-2012 06:24 AM in reply to: rakaev
    I ended up upgrading to 2012... it went away
    Active Member
    03-02-2012 06:54 AM in reply to: sgrinavi
    I have 2012 mechanical and have the same issue. I wait a few second to select the block.
    People please answer what to do!!!!
    Ruslan
    Active Member
    trevorcochran
    06-29-2012 11:28 AM in reply to: rakaev
    I have this same problem (ACAD 2011), extremely aggravating. However, I have found if I invoke a command before selection a block, there is no delay, but when selecting a single block with no command envoked there is a delay. I have this problem everyday during works hours (pipe is full), howevery when I am the only one working (pipe is wide open) there is never a delay, strange. I don't believe such an issue could be caused by hardware, but I am looking for any answer I can get.
