• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Product Support
    Accepted Solution
    3DConnexion Devices
    850 Views, 3 Replies
    10-03-2012 09:37 AM
    ACAD 2013 Device communication Issue:
    Users see issues with the following;
    • Zoom speed varies in perspective view
    • Pivot point position is far from the model causing the model to go off the drawing area when rotated
    • High zoom out speed after zooming in a small area of the drawing
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Product Support
    Re: 3DConnexion Devices
    10-03-2012 09:39 AM in reply to: MichaelBussiere2
    Autodesk 3Dconnexion Hotfix
    Download: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20605633&linkID=9240618
    This hotfix corrects the following issues with 3Dconnexion devices:
    Consult the readme file for installation instructions and more details on the primary issues resolved by this update. Be sure to install the correct hotfix (32-bit or 64-bit) for your software and operating system.
    Note: Before applying this hotfix to your Autodesk product, youmust install service pack 1-below (or SP1.1 for AutoCAD and AutoCAD LT).
    ACA2013 Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20556359&linkID=9240658
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    10-05-2012 03:32 AM in reply to: MichaelBussiere2
    Will this Hotfix work with Autocad Architecture 2012?
    Product Support
    10-05-2012 07:17 AM in reply to: MichaelBussiere2
    This will work with the following products,
    Applies to:
    AutoCAD® 2013
    AutoCAD® Architecture 2013
    AutoCAD® Civil 3D® 2013
    AutoCAD® Electrical 2013
    AutoCAD LT® 2013
    AutoCAD® Map 3D 2013
    AutoCAD® Mechanical 2013
    AutoCAD® MEP 2013
    AutoCAD® P&ID 2013
    AutoCAD® Plant 3D 2013
    AutoCAD® Raster Design 2013
    AutoCAD® Structural Detailing 2013
    AutoCAD® Utility Design 2013
    Michael Bussiere II
    Support Specialist
    Product Support
    Autodesk, Inc.
