• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    marc
    2013 hatch patterns
    6727 Views, 2 Replies
    04-06-2012 02:00 PM
    Ok, just got 2013 Architecture. How do I import hatch patterns into it.
    I have several stone pattens I use from StoneCAD and can't figure out how to get them into 2013.
    or
     Does anyone have a better source for stone hatch patterns and how to install them into 13?
    thankx!
    Please use plain text.
    Re: 2013 hatch patterns
    04-07-2012 05:22 AM in reply to: marc
    Are the hatch patterns you have in a folder that is in the AutoCAD search path?  To check, open the Options dialog and go to the Files tab.  Is the folder listed under the Working Support File Search Path node (second node from top)?  If not, go to the Support File Search Path node (top node) and add that folder (or moved the hatch patterns to a folder that is listed).
    David Koch
    marc
    04-09-2012 08:50 AM in reply to: David_W._Koch
    They were under a "hidden" folder in support. An "enu" folder that didn't show up until I did a file search for "*.pat".
    and then that folder could only be opened by right clicking the search findings and opening it that way.
     anyway, I think I got them transferred,
    thanks!
