We use profiles to define all sorts of things, the majority being door
slabs. The way profiles are currently set up, the dimensions of the
edges vary with the width of the door.
For example, on a full-lite door the OOTB profile has 4" sides and top
and a 12" bottom. However this is only when the door is 3'0"x6'8". If
the dimensions of the door vary from that size, the edges change in
size. It should be the glass changing in size with the sides staying
constant.
Dynamic Blocks allow you to define what portions will resize when
stretched. It would be *very* beneficial to have a similar function for
profiles.
Possibly as simple as the ability to define areas to scale in each axis.
Thank you,
John Colby
