AutoCAD Architecture Wishes
Active Contributor
ShenDesign
Message 1 of 5 (623 Views)
Please allow images to be bound to a file
623 Views, 4 Replies
11-15-2010 03:59 PM
Read in another post:  AutoCAD doesn't (yet) include image files in the drawing itself. Your best bet is to use ETRANSMIT, which puts all files needed in a ZIPped folder: photos, fonts, XREFs, etc.
I have a huge set of drawings with many photos of existing conditions.  When I transmit them to a colleague, none of the images are referenced.  They are all looking for the path on my computer.
Please enable images to be pathed and bound independently, liek dwg x-refs.  ("Insertobj" seems to only inserts a thumbnail, not the image.)
Thanks Adesk!
Valued Mentor
jmcintyre
Message 2 of 5 (621 Views)
Re: Please allow images to be bound to a file
11-15-2010 06:57 PM in reply to: ShenDesign
You can cut&paste an image into acad. Then it's not an external 'xref' and is saved within the DWG.
Distinguished Contributor
Oilymo
Message 3 of 5 (587 Views)
12-06-2010 08:55 AM in reply to: ShenDesign
This doesn't work for me.
If I cut and paste the image the path still appears on the external references palette.
Am I missing something?
Valued Mentor
jmcintyre
Message 4 of 5 (584 Views)
12-06-2010 01:04 PM in reply to: Oilymo
You need to open the image in paint or photoshop, select all, copy to clipboard, then paste in acad.
johnmacfall
Message 5 of 5 (348 Views)
12-29-2011 08:42 AM in reply to: ShenDesign
You can insert the image as an OLE object. It will be embedded in the drawing.
