Well, I seem to be stuck using the new xref manager pallet instead of the classic window, which I liked a LOT because I could change the path information in it and with the new pallet you are stuck with a LOT less options to control your xrefs. Does anyone have a work around that does not entail using the "classicxref" command or setting my "SDI" to 1?
I'd like to have multiple dwgs open and I'm not sure how to modify my ribbon commands, they all seem to point to preconceived commands.
Thanks for any help on this!
Solved by BlueRocco. Go to Solution.
Right-click for more options in the Xref palette and make sure the bottom list is open/visible.
or just go to the ClassicXref, there is no way to modify the core Xref palette.
CUI command if you want to customize the screen menu items.
Yea, I changed the screen menu. I was hoping someone had found a way to get around the upgrade. I guess I'll just have to get used to it.
Kind of like that little icon that appears in a row on your status bar evey time you open a drawing while in SDI "1" mode telling you that you just opened a trused autocad drawing..... what a laugh, as if you didn't just make the drawing
